주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Screen Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Screen Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Screen Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Screen Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
    • 3.32 mm head, 3.99 mm length.
    • 2.82 head 3.5 mm length.
    • 4.15 mm head, 2.35 mm length.
  7. HP Pavilion x2 10-n113dx Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x2 10-n113dx Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x2 10-n113dx Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Very carefully lift the circuit board in order to keep everything attached. Be careful with any cables that may still be connected.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Zambrano
회원 가입일: 09/28/17
837 평판
안내서 5개를 작성함
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G4
4 회원들
안내서 5개를 작성함
4가이드 댓글
where can i get the replacement screen for this model
Umer Muhammad Anwar - 답글
where can i get the replacement screen for this model?
Olumuyiwa Oyenuche - 답글
This guide is bad. He takes the same screws out twice. There is more than 21 screws. Do not follow this guide you will end up breaking something.
matthewcomley - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 30
전체 시간: 6,626
