주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Speaker Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Speaker Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Speaker Replacement: 2 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Speaker Replacement: 2 단계, 이미지 2/2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Speaker Replacement: 3 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement: 3 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement: 3 단계, 이미지 3/3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Speaker Replacement: 4 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement: 4 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement: 4 단계, 이미지 3/3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Speaker Replacement: 5 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement: 5 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: 6 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: 6 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement, Speaker: 6 단계, 이미지 3/3
    • To unscrew the first speaker, use the Phillips #0 screwdriver to unscrew the 2 screws- head 3.99mm, length 3.32 mm.
  7. HP Pavilion x2 10-n113dx Speaker Replacement: 7 단계, 이미지 1/1
    • For the second speaker, repeat the previous step by unscrewing the two screws.
  8. HP Pavilion x2 10-n113dx Speaker Replacement: 8 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Speaker Replacement: 8 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Speaker Replacement: 8 단계, 이미지 3/3
    • Gently remove the 1st and 2nd speaker from the assembly.
결론
David Zambrano
회원 가입일: 09/28/17
822 평판
안내서 5개 작성하였습니다
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S13G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 536
