주요 콘텐츠로 건너뛰기
HP Pavilion x2 10-n113dx Touch Pad Replacement
필요한 것
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: 1 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: 1 단계, 이미지 2/2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: 3 단계, 이미지 1/1
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: 4 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 4 단계, 이미지 2/2
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: 5 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 5 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 5 단계, 이미지 3/3
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: 6 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 6 단계, 이미지 2/2
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: 7 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 7 단계, 이미지 2/2
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: 8 단계, 이미지 1/2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 8 단계, 이미지 2/2
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: 9 단계, 이미지 1/3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 9 단계, 이미지 2/3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 9 단계, 이미지 3/3
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
결론
Cayla Skaggs
회원 가입일: 04/01/19
337 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 회원
IUPUI-HARLEY-S19S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 725
