주요 콘텐츠로 건너뛰기
HP Pavilion x360 11-p110nr Battery Replacement
필요한 것
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion x360 11-p110nr Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x360 11-p110nr Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
결론
작성자
5다른 기여자 명과 함께
AljeannaJohnson
회원 가입일: 09/20/17
202 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 19
전체 시간: 842
