주요 콘텐츠로 건너뛰기
HP Pavilion x360 11-p110nr Speakers Replacement
필요한 것
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 1 단계, 이미지 3개 중 3개
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement: 2 단계, 이미지 3개 중 3개
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Speakers Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Speakers Replacement: 6 단계, 이미지 3개 중 3개
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
결론
작성자
3다른 기여자 명과 함께
Aeorrell
회원 가입일: 03/27/23
433 평판
안내서 3개를 작성함
IUPUI, Team 1-2, Harley Spring 2023 IUPUI, Team 1-2, Harley Spring 2023 회원
IUPUI-HARLEY-S23S1G2
3 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 82
