주요 콘텐츠로 건너뛰기
HP Pavilion x360 11-p110nr Touchpad Replacement
필요한 것
  1. HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: 1 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: 1 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: 1 단계, 이미지 3개 중 3개
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Once the screws are removed, carefully take the bottom plate off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Touchpad Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Touchpad Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the five 6.7 mm screws that secure the battery.
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the hard drive.
    • Locate the cable for the battery and the cable for the speakers and unplug those as well.
  4. HP Pavilion x360 11-p110nr Touchpad Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Touchpad Replacement: 4 단계, 이미지 3개 중 3개
    • Once all screws are removed, carefully remove the battery and hard drive as one unit.
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  5. HP Pavilion x360 11-p110nr Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Once the battery and hard drive are removed, you should be able to see the touchpad.
  6. HP Pavilion x360 11-p110nr Touchpad Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Touchpad Replacement: 6 단계, 이미지 3개 중 3개
    • Find the cable for the touchpad and unplug it.
    • Remove and install carefully as to not damage the cable.
  7. HP Pavilion x360 11-p110nr Touchpad Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x360 11-p110nr Touchpad Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the touchpad bracket.
    • Slowly lift up the bracket and remove it.
  8. HP Pavilion x360 11-p110nr Touchpad Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion x360 11-p110nr Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the three 2.35 mm screws that secure the touchpad.
    • Remove the cover holding the touchpad in place.
  9. HP Pavilion x360 11-p110nr Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • You can now remove and replace the trackpad.
    • Be careful not to scratch the screen during the replacement of the trackpad as the screen will be located directly underneath the trackpad.
결론
작성자
2다른 기여자 명과 함께
Aeorrell
회원 가입일: 03/27/23
433 평판
안내서 3개를 작성함
IUPUI, Team 1-2, Harley Spring 2023 IUPUI, Team 1-2, Harley Spring 2023 회원
IUPUI-HARLEY-S23S1G2
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 165
