소개
A wireless chip is an integral part of your HP Pavilion x360 operation. It allows for connection to the internet without the use of a wired connection, as well as connection to other wireless devices. This guide will demonstrate step by step how to replace the wireless chip if it were to be damaged or upgraded.
필요한 것
Locate and remove all 11 of the screws.
Detach the cover by slowly pulling it from the base of the computer.
The wireless chip is square shaped, with white paper containing bar codes glued to it. The chip is in the top left section of the back (with the hinged edge facing away from you)
The chip will have a single wire connected to it. Carefully remove the wire connected to the chip using tweezers.
Unscrew the two screws near the top.
