주요 콘텐츠로 건너뛰기
HP Pavilion x360 14-ba253cl Display Replacement
필요한 것
  1. HP Pavilion x360 14-ba253cl Display Replacement, Display: 1 단계, 이미지 1/2 HP Pavilion x360 14-ba253cl Display Replacement, Display: 1 단계, 이미지 2/2
    • Insert an opening pick between the screen and top case to separate it from the laptop.
  2. HP Pavilion x360 14-ba253cl Display Replacement: 2 단계, 이미지 1/3 HP Pavilion x360 14-ba253cl Display Replacement: 2 단계, 이미지 2/3 HP Pavilion x360 14-ba253cl Display Replacement: 2 단계, 이미지 3/3
    • Once the screen is pryed away from the laptop, lay the screen face down onto the keyboard.
  3. HP Pavilion x360 14-ba253cl Display Replacement: 3 단계, 이미지 1/3 HP Pavilion x360 14-ba253cl Display Replacement: 3 단계, 이미지 2/3 HP Pavilion x360 14-ba253cl Display Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove any tape or wires that connect the screen and laptop together using tweezers.
  4. HP Pavilion x360 14-ba253cl Display Replacement: 4 단계, 이미지 1/1
    • Remove the display from the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Kyrah Ross
회원 가입일: 10/15/19
279 평판
안내서 1개 작성함
댓글 2개
If you came here looking for a lcd back cover replacement don't bother. You have to damage the new part to install. Horrible design.
Ender - 답글
This didn't help at all... You took as little pics as possible and didn't show the reinstall.
Cameron Coppoletta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 71
전체 시간: 6,070
