주요 콘텐츠로 건너뛰기
HP Pavilion x360 14-ba253cl Keyboard Replacement
필요한 것
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
92,282 평판
안내서 241개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,537개를 작성함
댓글 한 개
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 56
전체 시간: 7,667
