주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion x360 14-dw RAM Replacement
필요한 것
  1. HP Pavilion x360 14-dw RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1개 중 1개
    • Fully shut down your laptop and unplug all cables.
  2. HP Pavilion x360 14-dw RAM Replacement, Flip your laptop over: 2 단계, 이미지 1개 중 1개
    • Flip your laptop over so the rubber feet are facing up.
  3. HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement, Expose the back cover screws: 3 단계, 이미지 3개 중 3개
    • The ends of the rubber feet cover four back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
    • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
  4. HP Pavilion x360 14-dw RAM Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $8.95
    • Peel up the other ends of the feet to expose the three remaining screws.
    • During reassembly:
    • Press down firmly on the ends of the feet to secure them into their recesses.
    • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
  5. HP Pavilion x360 14-dw RAM Replacement, Unfasten the back cover: 5 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Unfasten the back cover: 5 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the five screws securing the back cover:
    • Four larger 6.7 mm-long black screws
    • One smaller 2.9 mm-long silver screw
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  6. HP Pavilion x360 14-dw RAM Replacement, Release the clips: 6 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Release the clips: 6 단계, 이미지 2개 중 2개
    • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top right corner of the back cover and the frame.
    • Pry up to release the clips securing the back cover.
  7. HP Pavilion x360 14-dw RAM Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap you just created.
    • Slide the spudger down to the bottom right corner to release the clips on the right edge.
  8. HP Pavilion x360 14-dw RAM Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
    • Slide the spudger to the bottom left corner to release the clips.
  9. HP Pavilion x360 14-dw RAM Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
    • Slide the spudger up to the top left corner to release the clips on the left edge.
  10. HP Pavilion x360 14-dw RAM Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Insert the flat side of an opening pick into the seam between the top edge of the back cover and frame, just to the right of the left hinge.
    • Pry up to release the clips.
  11. HP Pavilion x360 14-dw RAM Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement: 11 단계, 이미지 3개 중 3개
    • Slide the spudger towards the right hinge to release the remaining clips.
  12. HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: 12 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: 12 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement, Remove the back cover: 12 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
  13. HP Pavilion x360 14-dw RAM Replacement, Unfasten the battery: 13 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Unfasten the battery: 13 단계, 이미지 2개 중 2개
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the four 4.6 mm-long screws securing the battery.
  14. HP Pavilion x360 14-dw RAM Replacement, Remove the battery: 14 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Remove the battery: 14 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement, Remove the battery: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Some models may have a strip of tape covering the battery connector. Use a pair of blunt tweezers or your fingers to peel it up and remove it before removing the battery.
    • Remove the battery.
    • During reassembly, slide the bottom battery tabs into their slots on the frame, use the alignment posts to position the battery, and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  15. HP Pavilion x360 14-dw RAM Replacement, Remove the RAM shield: 15 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM shield: 15 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up around the edges of the metal shield covering the sticks of RAM.
    • Pry up evenly around the shield's perimeter to avoid damaging the clips securing it.
  16. HP Pavilion x360 14-dw RAM Replacement: 16 단계, 이미지 2개 중 1개 HP Pavilion x360 14-dw RAM Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the metal shield.
    • During reassembly, align the metal shield over its clips and press down around the perimeter to secure it.
  17. HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: 17 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: 17 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement, Unlatch the RAM: 17 단계, 이미지 3개 중 3개
    • Your laptop has two memory slots, each with a pair of metal arms that secure a stick of RAM.
    • Simultaneously push out the metal arms on each side of a stick of RAM until they disengage and the stick pops up at a slight angle.
  18. HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: 18 단계, 이미지 3개 중 1개 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: 18 단계, 이미지 3개 중 2개 HP Pavilion x360 14-dw RAM Replacement, Remove the RAM: 18 단계, 이미지 3개 중 3개
    • Pull the stick of RAM out of its socket to remove it.
    • Repeat for a second stick of RAM.
    • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
183,349 평판
안내서 1,165개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,536개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 72
지난 30일: 312
전체 시간: 6,327
