주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-ba011dx Speakers Replacement
필요한 것
  1. HP Pavilion x360 14m-ba011dx Speakers Replacement, Speakers: 1 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Speakers Replacement, Speakers: 1 단계, 이미지 2개 중 2개
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to locate the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Speakers Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the wires labeled 1 and 2 out.
  5. HP Pavilion x360 14m-ba011dx Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect two ZIF connectors from the motherboard.
    • Remove three 4mm screws using a Phillips #00 Screwdriver.
  6. HP Pavilion x360 14m-ba011dx Speakers Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the speakers from the device.
결론
작성자
3다른 기여자 명과 함께
Katie Pruis
회원 가입일: 01/16/20
820 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 6
전체 시간: 246
