주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-ba011dx Touchpad Replacement
필요한 것
  1. HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: 1 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: 1 단계, 이미지 2개 중 2개
    • Remove the top left and right rubber pads closest to the hinge of the screen using a plastic spudger to locate the screws underneath. ​
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Push into the two screw holes located under the rubber pads with the screwdriver to pop the keyboard out slightly.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove the keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white clasps that hold the three cables to the motherboard open and unplug the cables.
  4. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the now removed keyboard over to expose the bottom side.
    • Unclasp the cable that connects the touchpad to the keyboard.
    • You can remove this cable the same way you removed the previous cables.
    • Remove the six 2.3 mm screws that attach the touch pad using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Touchpad Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx Touchpad Replacement: 5 단계, 이미지 2개 중 2개
    • Pull off the metal piece holding the touchpad in place.
    • Remove the touchpad from the device.
결론
작성자
2다른 기여자 명과 함께
Katie Pruis
회원 가입일: 01/16/20
820 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 39
전체 시간: 1,750
