주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Battery Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Mason T Arruda
회원 가입일: 03/22/22
171 평판
안내서 1개를 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개를 작성함
1가이드 댓글
Hallo
vielen Dank für diese coole Anleitung
als Ergänzung
beim Model 14-cd0101ng gibt es lediglich die beiden unteren Schrauben (siehe schritt, zwei 6mm schrauben) nicht.
Ansonsten konnte ich keine unterschiede feststellen!
Eng:
For Model 14-cd0101ng it is the same way, without the two 6mm Phillips screws underneath!
Erwin “ReudenBub” Po - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 54
전체 시간: 2,711
