주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Fan Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the heat sink assembly from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Riley McMorrow
회원 가입일: 03/22/22
273 평판
안내서 1개를 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 14
전체 시간: 544
