주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Hinges Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 3 단계, 이미지 1개 중 1개
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 4 단계, 이미지 2개 중 2개
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 5 단계, 이미지 2개 중 2개
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 6 단계, 이미지 1개 중 1개
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 7 단계, 이미지 3개 중 3개
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 8 단계, 이미지 1개 중 1개
    • After the cable has been disconnected, the screen can be removed.
  9. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Hinges: 9 단계, 이미지 1개 중 1개
    • Remove the three Phillip Head screws (5 mm)that hold in the bracket on each side.
  10. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 10 단계, 이미지 1개 중 1개
    • Slide the frame down past the brackets on each side.
  11. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 11 단계, 이미지 3개 중 3개
    • Lay the laptop flat on your working surface.
    • Flip it over to get access to the back panel.
    • Remove the back panel screws and take off the back cover.
  12. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 12 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the 5 mm screws from the hinges on each side inside the laptop.
  13. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 13 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the hinges from both sides of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elijah Jope
회원 가입일: 03/22/22
379 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 42
전체 시간: 3,085
