주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx SSD Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Make sure computer is turned off
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx SSD Replacement: 2 단계, 이미지 1/3 HP Pavilion x360 14m-cd0003dx SSD Replacement: 2 단계, 이미지 2/3 HP Pavilion x360 14m-cd0003dx SSD Replacement: 2 단계, 이미지 3/3
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx SSD Replacement: 3 단계, 이미지 1/2 HP Pavilion x360 14m-cd0003dx SSD Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the 5 mm screw that secures the SSD.
  4. HP Pavilion x360 14m-cd0003dx SSD Replacement: 4 단계, 이미지 1/2 HP Pavilion x360 14m-cd0003dx SSD Replacement: 4 단계, 이미지 2/2
    • Peel back the black covering.
    • Pull out SSD.
결론
Jack Benfeito
회원 가입일: 03/22/22
177 평판
안내서 1개 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 734
