주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Screen Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Screen Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Screen Replacement: 3 단계, 이미지 1/1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Screen Replacement: 4 단계, 이미지 1/2 HP Pavilion x360 14m-cd0003dx Screen Replacement: 4 단계, 이미지 2/2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Screen Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 14m-cd0003dx Screen Replacement: 5 단계, 이미지 2/2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Screen Replacement: 6 단계, 이미지 1/1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Screen Replacement: 7 단계, 이미지 1/3 HP Pavilion x360 14m-cd0003dx Screen Replacement: 7 단계, 이미지 2/3 HP Pavilion x360 14m-cd0003dx Screen Replacement: 7 단계, 이미지 3/3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Screen Replacement: 8 단계, 이미지 1/1
    • After the cable has been disconnected, the screen can be removed.
결론
Elijah Jope
회원 가입일: 03/22/22
376 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 584
