주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 4 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 4 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 4 단계, 이미지 3개 중 3개
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
결론
작성자
3다른 기여자 명과 함께
Elijah Jope
회원 가입일: 03/22/22
379 평판
안내서 3개를 작성함
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 회원
UMASSD-SINCLAIRE-S22S7G4
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 544
