주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement
필요한 것
  1. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 6 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 6 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 6 단계, 이미지 3개 중 3개
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Heat Sink and Fan: 8 단계, 이미지 1개 중 1개
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 11 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 10
전체 시간: 545
