주요 콘텐츠로 건너뛰기
HP Pavilion x360 15t-br000 Battery Replacement
필요한 것
  1. HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: 1 단계, 이미지 1/3 HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: 1 단계, 이미지 2/3 HP Pavilion x360 15t-br000 Battery Replacement, Keyboard Panel: 1 단계, 이미지 3/3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Battery Replacement: 2 단계, 이미지 1/3 HP Pavilion x360 15t-br000 Battery Replacement: 2 단계, 이미지 2/3 HP Pavilion x360 15t-br000 Battery Replacement: 2 단계, 이미지 3/3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Battery Replacement: 4 단계, 이미지 1/2 HP Pavilion x360 15t-br000 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
결론
xi yang
회원 가입일: 10/01/19
403 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 21
전체 시간: 823
