주요 콘텐츠로 건너뛰기
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
필요한 것
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 1 단계, 이미지 3개 중 1개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 1 단계, 이미지 3개 중 2개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 1 단계, 이미지 3개 중 3개
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 3 단계, 이미지 3개 중 3개
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
xi yang
회원 가입일: 10/01/19
409 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 563
