주요 콘텐츠로 건너뛰기
HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement
필요한 것
  1. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: 1 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: 1 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the center bottom.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw from all four corners of the bottom cover.
  3. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 3 단계, 이미지 3개 중 3개
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove all four of the 4 mm screws that secure each corner of the battery.
  5. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 5 단계, 이미지 3개 중 3개
    • Use the opening tool near the connector to gently apply pressure and lift the battery away from the device.
    • Once loose, lift the battery from the connector side to separate it from the device.
    • The stabilizer for the battery (small black part held in by the top left screw) may come loose. Leave the part in its original position.
  6. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 3개
  7. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 7 단계, 이미지 3개 중 3개
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  8. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 8 단계, 이미지 3개 중 3개
  9. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Use PH1 to remove all four of the 4mm screws on each corner of the battery.
  10. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 10 단계, 이미지 3개 중 3개
  11. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • To unplug the trackpad, remove both stickers with angled tweezers.
    • Lift the connector clasp with spudger.
    • Use angled tweezers to lightly grip the ribbon cable and pull it out to lift cable off of black cover
  12. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 12 단계, 이미지 2개 중 2개
    • Using the angled tweezers, grip one corner of the black cover and lift.
  13. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 13 단계, 이미지 1개 중 1개
    • Hold back the black cover with one hand.
    • Use the PH0 screwdriver to remove three black screws (2.5mm) located at the top of the trackpad.
  14. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 14 단계, 이미지 2개 중 2개
    • Using the PH1 screwdriver, remove four screws (3mm) at the bottom of the trackpad.
    • Lift the metal cover off.
  15. HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 15 단계, 이미지 3개 중 1개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 15 단계, 이미지 3개 중 2개 HP Pavilion x360 Convertible 14-dw1025nr Trackpad Replacement: 15 단계, 이미지 3개 중 3개
    • Hold back the black cover.
    • Use the angled tweezers to grip the metal screw tab located in the middle of the trackpad.
    • Lift up and away to remove the trackpad part.
결론
작성자
3다른 기여자 명과 함께
Amber Norton
회원 가입일: 09/14/22
661 평판
안내서 4개를 작성함
0 Guide Comments
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 363
