주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u001dx Battery Replacement
필요한 것
  1. HP Pavilion x360 m3-u001dx Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Battery Replacement: 2 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Battery Replacement: 2 단계, 이미지 2/2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Battery Replacement: 3 단계, 이미지 1/1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Battery Replacement: 4 단계, 이미지 1/1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Battery Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Battery Replacement: 5 단계, 이미지 2/2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Battery Replacement: 6 단계, 이미지 1/1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Battery Replacement: 7 단계, 이미지 1/1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Battery Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Battery Replacement, Battery: 9 단계, 이미지 1/1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Battery Replacement: 10 단계, 이미지 1/1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
결론
Follow these instructions in reverse order to reassemble your device.
다른 7명이 해당 안내서를 완성하였습니다.
Subhleen
회원 가입일: 02/01/17
1,268 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 1-6, Rose Winter 2017 UW Tacoma, Team 1-6, Rose Winter 2017 회원
UWT-ROSE-W17S1G6
4 회원들
안내서 8개 작성하였습니다
댓글 2개
Thanks for this easy step by step guide. The pictures were incredibly helpful!
azbeasleys - 답글
I replaced the battery now the screen doesn't turn on. I plugged it into an external monitor and the computer works fine and even the touch aspect of the screen works, but it stays black. Did i accidentally disconnect something?
G Bates - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 13
전체 시간: 7,251
