주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u001dx Hard Drive Replacement
필요한 것
  1. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Keyboard: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 4 단계, 이미지 1/1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 5 단계, 이미지 2/2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 6 단계, 이미지 1/1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 7 단계, 이미지 1/1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Battery: 9 단계, 이미지 1/1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 10 단계, 이미지 1/1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Hard Drive: 11 단계, 이미지 1/1
    • Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
    • Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  12. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 12 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 12 단계, 이미지 2/2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
  13. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 13 단계, 이미지 1/1
    • Using the tab provided, lift and remove the hard drive out of the laptop base.
  14. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 14 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 14 단계, 이미지 2/2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
    • There are 2 Phillips screws on each side of the hard drive bracket.
  15. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 15 단계, 이미지 1/1
    • Remove the mounting bracket.
결론
Follow these instructions in reverse order to reassemble your device.
다른 9명이 해당 안내서를 완성하였습니다.
Subhleen
회원 가입일: 02/01/17
1,268 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 1-6, Rose Winter 2017 UW Tacoma, Team 1-6, Rose Winter 2017 회원
UWT-ROSE-W17S1G6
4 회원들
안내서 8개 작성하였습니다
댓글 8개
Awesome. Thanks. This helped me a lot.
Gouse Khan - 답글
Can anyone tell me the model number of the hdd ribbon cable please :)
James Harris - 답글
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
KurwynK - 답글
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get  3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
downdog89 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 60
전체 시간: 22,262
