주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u001dx System Board Replacement
필요한 것
  1. HP Pavilion x360 m3-u001dx System Board Replacement, Keyboard: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx System Board Replacement: 2 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx System Board Replacement: 2 단계, 이미지 2/2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx System Board Replacement: 3 단계, 이미지 1/1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx System Board Replacement: 4 단계, 이미지 1/1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx System Board Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx System Board Replacement: 5 단계, 이미지 2/2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx System Board Replacement: 6 단계, 이미지 1/1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx System Board Replacement: 7 단계, 이미지 1/1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx System Board Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx System Board Replacement, Battery: 9 단계, 이미지 1/1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx System Board Replacement: 10 단계, 이미지 1/1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: 11 단계, 이미지 1/3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: 11 단계, 이미지 2/3 HP Pavilion x360 m3-u001dx System Board Replacement, USB Port Shield: 11 단계, 이미지 3/3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): 12 단계, 이미지 1/3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): 12 단계, 이미지 2/3 HP Pavilion x360 m3-u001dx System Board Replacement, System Board (Motherboard): 12 단계, 이미지 3/3
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx System Board Replacement: 13 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx System Board Replacement: 13 단계, 이미지 2/2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx System Board Replacement: 14 단계, 이미지 1/2 HP Pavilion x360 m3-u001dx System Board Replacement: 14 단계, 이미지 2/2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx System Board Replacement: 15 단계, 이미지 1/3 HP Pavilion x360 m3-u001dx System Board Replacement: 15 단계, 이미지 2/3 HP Pavilion x360 m3-u001dx System Board Replacement: 15 단계, 이미지 3/3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx System Board Replacement: 16 단계, 이미지 1/1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u001dx System Board Replacement: 17 단계, 이미지 1/1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx System Board Replacement: 18 단계, 이미지 1/1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
결론
Follow these instructions in reverse order to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
_ thinhh@uw.edu
회원 가입일: 02/01/17
297 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-6, Rose Winter 2017 UW Tacoma, Team 1-6, Rose Winter 2017 회원
UWT-ROSE-W17S1G6
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 17
전체 시간: 3,859
