소개
Use this disassembly guide if you are looking to replace your Random Access Memory within your HP Pavilion x360 m3-u101dx laptop. This guide will aid you with finding your way towards the RAM and ensure you do not lose track of what to do next.
For this guide, you will need Phillips #1 Screwdriver heads and a plastic opening tool to find your way towards the RAM. Make sure to very careful with cable wires along the way so you do not break other parts of the computer by mistake.
필요한 것
Lift open the laptop screen and flip it around so that the keyboard is facing up.
Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
Detach the keyboard panel from the frame.
Use a plastic opening tool to lift the battery cable out from the motherboard.
Disconnect the seven ribbon cables connected to the motherboard using a finger or plastic opening tool.
다른 2명이 해당 안내서를 완성하였습니다.
