주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u103dx Battery Replacement
필요한 것
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: 2 단계, 이미지 1/1
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: 3 단계, 이미지 1/1
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: 4 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx Battery Replacement: 4 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx Battery Replacement: 4 단계, 이미지 3/3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Battery Replacement: 5 단계, 이미지 2/2
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: 7 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Battery Replacement: 7 단계, 이미지 2/2
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Meaghan Hyatt
회원 가입일: 01/17/19
355 평판
안내서 2개 작성하였습니다
댓글 한 개
Can i use the laptop even without a battery??
PAPISSS PH - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 57
전체 시간: 6,731
