주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u103dx Fan Replacement
필요한 것
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: 2 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Fan Replacement: 2 단계, 이미지 2/2
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: 3 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx Fan Replacement: 3 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx Fan Replacement: 3 단계, 이미지 3/3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: 4 단계, 이미지 1/1
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: 5 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx Fan Replacement: 5 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx Fan Replacement: 5 단계, 이미지 3/3
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: 6 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Fan Replacement: 6 단계, 이미지 2/2
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Meaghan Hyatt
회원 가입일: 01/17/19
355 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 1,287
