주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement
필요한 것
  1. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Power off Device.
    • Working device while it is powered on may cause damage to laptop or electric shock.
  2. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip over laptop
    • Remove the rubber foot with a Metal Spudger
  3. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws.
    • 5 Phillips 2.0 x 5.0 mm screws.
    • Make sure to keep different screw types separated.
  4. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 4 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 4 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 4 단계, 이미지 3/3
    • Flip the laptop over to screen and keyboard side.
    • Using a Metal Spudger pop open keyboard from base of laptop.
    • Be cautious of three wires on the inside of the keyboard connecting it to the motherboard.
  5. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 5 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 5 단계, 이미지 2/2
    • Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
  6. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 6 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 6 단계, 이미지 2/2
    • After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Teresita Aragon
회원 가입일: 01/17/19
566 평판
안내서 1개 작성함
댓글 한 개
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
k.kolish2493 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 681
