주요 콘텐츠로 건너뛰기
HP Pavilion x360 m3-u103dx Motherboard Replacement
필요한 것
  1. HP Pavilion x360 m3-u103dx Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Power the device off.
    • Flip the device over.
    • Using the plastic spudger, remove the rubber bumper to reveal 5 screws.
  2. HP Pavilion x360 m3-u103dx Motherboard Replacement: 2 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove 10 screws from the back plate.
    • Five 2.4 x 5.7 mm screws.
    • Five 2.8 x 5.0 mm screws.
  3. HP Pavilion x360 m3-u103dx Motherboard Replacement: 3 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 3 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 3 단계, 이미지 3/3
    • Using the plastic opening tool, pry the keyboard upwards at the opening shown.
    • Then, using the metal spudger, pry around the rest of the keyboard until it is completely free.
    • Slowly, lift the entire keyboard up and away from the screen to reveal the connections and internals.
    • The connector ribbons can be damaged if the keyboard is lifted too high.
  4. HP Pavilion x360 m3-u103dx Motherboard Replacement: 4 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 4 단계, 이미지 2/2
    • Using the black nylon spudger, lift the retaining clip for each ribbon shown.
    • Lift the keyboard out of the device and out of the way.
  5. HP Pavilion x360 m3-u103dx Motherboard Replacement: 5 단계, 이미지 1/3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 5 단계, 이미지 2/3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a J000 screwdriver, remove 9 screws from the motherboard.
    • Using a Y1 screwdriver, remove the 10th screw from the top of the motherboard.
    • Tweezers can be helpful to pull screws from tight areas.
    • Grounding bracelets can prevent static from harming delicate electronics.
  6. HP Pavilion x360 m3-u103dx Motherboard Replacement: 6 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 6 단계, 이미지 2/2
    • Using a spudger, flip the retaining clips for these two ribbons and gently pull them away from their sockets.
    • Using tweezers, gently pull this connector away from its socket.
  7. HP Pavilion x360 m3-u103dx Motherboard Replacement: 7 단계, 이미지 1/2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 7 단계, 이미지 2/2
    • Gently lift the entire motherboard while tilting it to the left side of the laptop.
    • Disconnect the final plug from underneath the motherboard.
    • Lift the old motherboard from the laptop completely.
결론
Nicholas Bassett
회원 가입일: 09/03/19
145 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Hovde Fall 2019 IUPUI, Team S1-G2, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 549
