주요 콘텐츠로 건너뛰기
HP Pavilion zd8000 Keyboard Replacement
필요한 것
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
결론
작성자
5다른 기여자 명과 함께
Allie Menard
회원 가입일: 04/12/11
820 평판
안내서 13개를 작성함
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G56
4 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 4,145
