주요 콘텐츠로 건너뛰기
HP Pavilion zd8000 Motherboard Replacement
필요한 것
  1. HP Pavilion zd8000 Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Motherboard Replacement, RAM: 3 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, RAM: 3 단계, 이미지 2개 중 2개
    • Loosen the Phillips screw labeled ‘ram’ and lift the cover.
  4. HP Pavilion zd8000 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the green RAM card and find the metal tabs securing the card.
    • Push outwards on the two tabs to release the card.
  5. HP Pavilion zd8000 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully slide the card out at an upward angle away from the slot.
  6. HP Pavilion zd8000 Motherboard Replacement, WiFi Card Cables: 6 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, WiFi Card Cables: 6 단계, 이미지 2개 중 2개
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  7. HP Pavilion zd8000 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  8. HP Pavilion zd8000 Motherboard Replacement, CD/Optical Drive: 8 단계, 이미지 1개 중 1개
    • Remove the 8mm Philips screw located between the hard drive and the WiFi card.
  9. HP Pavilion zd8000 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Turn the laptop 90 degrees clockwise so you are facing the CD drive.
    • Unbend a paperclip and insert the end into the small hole by the eject button to cause the tray to pop out towards you.
  10. HP Pavilion zd8000 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Gently pull the tray away from the laptop and the rest of the optical drive will follow.
  11. HP Pavilion zd8000 Motherboard Replacement, Keyboard: 11 단계, 이미지 1개 중 1개
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  12. HP Pavilion zd8000 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  13. HP Pavilion zd8000 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  14. HP Pavilion zd8000 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
  15. HP Pavilion zd8000 Motherboard Replacement, Switch Cover: 15 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, Switch Cover: 15 단계, 이미지 2개 중 2개
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  16. HP Pavilion zd8000 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Flip the laptop over.
    • Fully open the laptop.
  17. HP Pavilion zd8000 Motherboard Replacement: 17 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 17 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
  18. HP Pavilion zd8000 Motherboard Replacement, Screen: 18 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, Screen: 18 단계, 이미지 2개 중 2개
    • Close the lid and rotate the laptop so that the vents are facing you.
    • Unscrew the two 8mm Philips screws below the hinges.
  19. HP Pavilion zd8000 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Carefully rotate the laptop 90 degrees counter-clockwise and open the screen.
    • Pull on the black tab with the HP service sticker to unplug the display from the motherboard.
  20. HP Pavilion zd8000 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the black cable from the hole leading to the WiFi enclosure.
    • Pull gently to remove the black and grey cables from the case.
    • Check the surface beneath the laptop to ensure the cables do not catch on anything when you flip the laptop over.
  21. HP Pavilion zd8000 Motherboard Replacement: 21 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 21 단계, 이미지 2개 중 2개
    • Using tweezers, pull the black cable towards the display and through the hole in the casing.
  22. HP Pavilion zd8000 Motherboard Replacement: 22 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 22 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 22 단계, 이미지 3개 중 3개
    • Unscrew the two 8mm Philips screws that attach the hinge to the laptop's display.
    • Lift the screen upwards to detach it from the laptop.
  23. HP Pavilion zd8000 Motherboard Replacement, Top Cover: 23 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, Top Cover: 23 단계, 이미지 2개 중 2개
    • With the laptop face-down, remove the eleven 8mm Philips screws.
  24. HP Pavilion zd8000 Motherboard Replacement: 24 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 24 단계, 이미지 2개 중 2개
    • Rotate the laptop 180 degrees so the vents are facing you.
    • Unscrew the four 3mm Philips screws below the vents.
  25. HP Pavilion zd8000 Motherboard Replacement: 25 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 25 단계, 이미지 2개 중 2개
    • Rotate the laptop 90 degrees counter-clockwise.
    • Unscrew the two 3mm Philips screws from the optical drive bay.
  26. HP Pavilion zd8000 Motherboard Replacement: 26 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 26 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 26 단계, 이미지 3개 중 3개
    • Flip the laptop over so it is face-up with the trackpad closest to you.
    • Locate the ribbon cable directly above the track pad.
    • Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
  27. HP Pavilion zd8000 Motherboard Replacement: 27 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 27 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 27 단계, 이미지 3개 중 3개
    • Find the ribbon cable on the LED board located at the top of the laptop.
    • You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
  28. HP Pavilion zd8000 Motherboard Replacement: 28 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 28 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the white connector attached to a red and black cable to the right of the LED board.
    • Using tweezers, pull the white connector away from you.
  29. HP Pavilion zd8000 Motherboard Replacement: 29 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 29 단계, 이미지 2개 중 2개
    • Unscrew the four 8mm Philips screws from the top cover.
  30. HP Pavilion zd8000 Motherboard Replacement: 30 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 30 단계, 이미지 2개 중 2개
    • Rotate the computer 90 degrees clockwise and insert the spudger at the seam above the card reader.
    • While lifting the front end of the top cover, slide the spudger across the seam.
    • When you have reached the firewire port, it should click open.
  31. HP Pavilion zd8000 Motherboard Replacement: 31 단계, 이미지 1개 중 1개
    • Lift the top cover from the left side to remove it completely.
  32. HP Pavilion zd8000 Motherboard Replacement, USB Module: 32 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, USB Module: 32 단계, 이미지 2개 중 2개
    • Locate the USB Module
    • Grip the yellow cable cover and pull it to the right to release it.
  33. HP Pavilion zd8000 Motherboard Replacement: 33 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 33 단계, 이미지 2개 중 2개
    • Unscrew the 6mm Philips screw connecting the USB module to the fan.
  34. HP Pavilion zd8000 Motherboard Replacement: 34 단계, 이미지 1개 중 1개
    • Pull the module to the right and lift it out to release it.
  35. HP Pavilion zd8000 Motherboard Replacement, Motherboard: 35 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement, Motherboard: 35 단계, 이미지 2개 중 2개
    • Unscrew and remove the five 4mm Philips screws marked with the white Phillips screw icon.
  36. HP Pavilion zd8000 Motherboard Replacement: 36 단계, 이미지 1개 중 1개
    • Unscrew and remove the two 8mm Philips screws from the heat sink fan.
  37. HP Pavilion zd8000 Motherboard Replacement: 37 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the digital drive board cable - the cable set on the right with black, red, green, and white wires.
    • Using tweezers, remove the the rigth speaker cable - the cable set on the left with red and black wires - by pulling the white connector towards you.
  38. HP Pavilion zd8000 Motherboard Replacement: 38 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 38 단계, 이미지 2개 중 2개
    • Using tweezers, remove the left speaker cable by pulling the white connector towards you.
  39. HP Pavilion zd8000 Motherboard Replacement: 39 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 39 단계, 이미지 2개 중 2개
    • Remove the LED board cable by pulling the white tab towards you.
  40. HP Pavilion zd8000 Motherboard Replacement: 40 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 40 단계, 이미지 2개 중 2개
    • Remove the audio cable - the one with the yellow covering located at the bottom-right corner of the motherboard - by pulling the yellow covering towards you.
  41. HP Pavilion zd8000 Motherboard Replacement: 41 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 41 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 41 단계, 이미지 3개 중 3개
    • Rotate the laptop 180 degrees and locate the Bluetooth module at the bottom-left corner of the motherboard.
    • Using tweezers, remove the Bluetooth module’s white connector by pulling it away from you.
  42. HP Pavilion zd8000 Motherboard Replacement: 42 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 42 단계, 이미지 2개 중 2개
    • Using tweezers, pull up on the Bluetooth module to remove it.
  43. HP Pavilion zd8000 Motherboard Replacement: 43 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 43 단계, 이미지 2개 중 2개
    • Remove the fan cable by pulling the white connector away from you.
  44. HP Pavilion zd8000 Motherboard Replacement: 44 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 44 단계, 이미지 2개 중 2개
    • Using pliers, unscrew and remove the two bolts from both sides of the blue VGA connector.
  45. HP Pavilion zd8000 Motherboard Replacement: 45 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 45 단계, 이미지 2개 중 2개
    • Carefully flip the laptop face-down with the battery compartment facing you.
    • Using tweezers, remove the black and red cable from the RAM compartment by pulling on the white connector.
  46. HP Pavilion zd8000 Motherboard Replacement: 46 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 46 단계, 이미지 2개 중 2개
    • Flip the laptop face-up and turn it so that the drive labelled "hp usb digital drive" faces you.
    • Press the ridged space saver card above the "hp usb digital drive" label to eject and remove it.
  47. HP Pavilion zd8000 Motherboard Replacement: 47 단계, 이미지 3개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 47 단계, 이미지 3개 중 2개 HP Pavilion zd8000 Motherboard Replacement: 47 단계, 이미지 3개 중 3개
    • Locate the PC card below the SD card reader.
    • Push the button to its left once to eject the button itself, then press it once again to remove the PC card.
  48. HP Pavilion zd8000 Motherboard Replacement: 48 단계, 이미지 1개 중 1개
    • Once the PC card pops out, pull it out.
  49. HP Pavilion zd8000 Motherboard Replacement: 49 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 49 단계, 이미지 2개 중 2개
    • Turn the computer 90 degrees counter-clockwise and clear all cables off of the motherboard.
    • Push in the grey button to the left of the PC card as far as possible.
    • Keeping the button pressed down, lift the motherboard up until the button pops out the top of the case.
  50. HP Pavilion zd8000 Motherboard Replacement: 50 단계, 이미지 1개 중 1개
    • Pull the right casing to the side to release the ports on the motherboard from it.
  51. HP Pavilion zd8000 Motherboard Replacement: 51 단계, 이미지 2개 중 1개 HP Pavilion zd8000 Motherboard Replacement: 51 단계, 이미지 2개 중 2개
    • Lift the motherboard up until it releases from the bottom casing and remove it from the laptop.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Allie Menard
회원 가입일: 04/12/11
820 평판
안내서 13개를 작성함
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G56
4 회원들
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 19,486
