주요 콘텐츠로 건너뛰기
HP Pavilion ze4530US Keyboard Replacement
필요한 것
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: 2 단계, 이미지 1/2 HP Pavilion ze4530US Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: 3 단계, 이미지 1/1
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: 4 단계, 이미지 1/1
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: 6 단계, 이미지 1/1
    • You have successfully removed the keyboard.
결론
Sonny Sem
회원 가입일: 10/11/16
356 평판
안내서 3개 작성하였습니다
Texas Tech, Team 38-5, Bennett Fall 2016 Texas Tech, Team 38-5, Bennett Fall 2016 회원
TTU-BENNETT-F16S38G5
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 165
