주요 콘텐츠로 건너뛰기
HP Pavilion zv5000 Hard Drive Replacement
필요한 것
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion zv5000 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion zv5000 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion zv5000 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Eliza Marks
회원 가입일: 10/18/16
649 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-6, Catania Fall 2016 UMass Dartmouth, Team 4-6, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G6
3 회원들
안내서 5개를 작성함
댓글 한 개
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 17
전체 시간: 3,088
