주요 콘텐츠로 건너뛰기
HP Pavilion15z-eh000 SSD Replacement
필요한 것
  1. HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: 1 단계, 이미지 3개 중 1개 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: 1 단계, 이미지 3개 중 2개 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: 1 단계, 이미지 3개 중 3개
    • Remove the two M2.0 × 5.0 Phillips screws along the bottom of the cover.
    • Remove the four Phillips M2.5 × 6.5 screws under the rubber foot pads.
    • The rubber pads have adhesive that allows them to be restuck after being lifted. You do not need to completely remove them, only partially.
  2. HP Pavilion15z-eh000 SSD Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion15z-eh000 SSD Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion15z-eh000 SSD Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening tool to pry open the bottom case, starting from the hinge.
    • Follow along the edge and use the opening tool to lever it open.
    • Recommended to start from the hinge as it will be easier, but it is possible to start anywhere.
  3. HP Pavilion15z-eh000 SSD Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion15z-eh000 SSD Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion15z-eh000 SSD Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the six Phillips M2.0 × 4.0 screws holding the battery in place.
    • Lift the battery slightly and pull it to disconnect it from the connector on the motherboard.
  4. HP Pavilion15z-eh000 SSD Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion15z-eh000 SSD Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion15z-eh000 SSD Replacement: 4 단계, 이미지 3개 중 3개
    • Finally, remove the Phillips M2.0 × 2.5 screw that secures the SSD to the motherboard.
    • Grasp the SSD by the edges and gently pull it out from its slot.
    • After removing the screw, the SSD will partially lift itself. Make note of the angle. When installing your new SSD be sure to insert it at the same angle.
결론
작성자
1다른 기여자 명과 함께
Bryan Segovia
회원 가입일: 10/26/22
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 31
전체 시간: 892
