소개
Acht zu allererst darauf, dass das Gerät abgeschaltet und von jeder Stromversorgung getrennt ist.
필요한 것
Nutze einen Spudger, um die zwei Gummifüße auf der Seite mit den Scharnieren des Laptops zu entfernen. Darunter verbergen sich zwei 9mm-Schrauben.
Du musst elf Schrauben entfernen.
Vier 9mm-Schrauben mit dem PH0-Schraubendreher.
Sieben 6mm-Schrauben mit dem PH0-Schraubendreher.
Nutze den Spudger, um die Ecken des Laptops bei den Displayscharnieren aufzuhebeln.
Heble mit dem Plastiköffnungswerkzeug entlang der Naht des Laptops, bis sich die Abdeckung löst.
Nutze das Plastik-Öffnerwerkzeug, um die weiße Sicherung von der Verbindung zu öffnen.
Zieh das Kabel heraus.
Um das Gerät wieder zusammenzubauen, folge den Anweisungen in umgekehrter Reihenfolge.
다른 27명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 11개
exellent and easy steps............but......where do i buy battery.....?
Muy bueno parece facil
Great step by step explanation. Solid pictures!!! Could not have fixed this without your contribution!!!
Purchased this laptop 28/12/2015 and now its just not switching on at all. I will try the repair instructions but I think it should have lasted a bit longer, what ever the problem is. The store where I bought it have checked the cable for me to see if that was the problem and it wasn’t. They wanted £60 to send it off, to find out the issue before anything was even done. The sales assistant said it could be the battery but he said it should have lasted longer. He basically said if its the motherboard you may as well just throw it out. I am sick of paying £100’s out for electrical items that live very short lives. My daughter bought this with her own money that she had been saving. I would not purchase this make of laptop again and where do I get a replacement battery and how much is that likely to be?
