주요 콘텐츠로 건너뛰기
HP Pavillion G60-120US LCD Screen Replacement
필요한 것
  1. HP Pavillion G60-120US LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is turned off.
    • Turn the laptop over to reveal the battery.
  2. HP Pavillion G60-120US LCD Screen Replacement: 2 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 2 단계, 이미지 2/2
    • Slide and hold the battery release switch to the left to release the battery from the device.
  3. HP Pavillion G60-120US LCD Screen Replacement: 3 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 3 단계, 이미지 2/2
    • While holding the battery release switch, grab the battery and pull it upward gently.
  4. HP Pavillion G60-120US LCD Screen Replacement, Keyboard: 4 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
  5. HP Pavillion G60-120US LCD Screen Replacement: 5 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 5 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove two 4.0mm screws from the hard disk cover.
    • Remove the hard disk cover.
  6. HP Pavillion G60-120US LCD Screen Replacement: 6 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 6 단계, 이미지 2/2
    • Remove the hard drive by pulling gently and disconnecting the hard drive from the laptop.
    • Gently pull on the black and red wiring on the bottom left to separate the wire from the component.
  7. HP Pavillion G60-120US LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the two 4.0 mm Phillips #0 screws from the hard disk compartment.
  8. HP Pavillion G60-120US LCD Screen Replacement: 8 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 8 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 8 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the two 4.0 mm screws from the memory card cover.
    • Remove the memory disk cover.
  9. HP Pavillion G60-120US LCD Screen Replacement: 9 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 9 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 9 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw from the Wi-Fi chip cover.
    • Remove the Wi-Fi chip cover.
  10. HP Pavillion G60-120US LCD Screen Replacement: 10 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 10 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the two 3.0 mm screws securing the Wi-Fi chip in place.
    • Grab the Wi-Fi chip and pull up gently to the left to disconnect it from the laptop.
  11. HP Pavillion G60-120US LCD Screen Replacement: 11 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 11 단계, 이미지 2/2
    • Disconnect the two wires connecting the chip's base.
    • Remove the Wi-Fi chip.
  12. HP Pavillion G60-120US LCD Screen Replacement: 12 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the seven 4.0 mm screws on the bottom of the laptop.
  13. HP Pavillion G60-120US LCD Screen Replacement: 13 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 13 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 13 단계, 이미지 3/3
    • Turn the laptop back to its upright state.
    • Insert an opening tool into the upper right corner of the keyboard and gently lift it to separate it from the laptop.
    • Be sure not to apply excessive pressure to prevent the bending and breaking of the keyboard.
    • Do not pull the keyboard all the way out because there is a wiring connection under the keyboard.
  14. HP Pavillion G60-120US LCD Screen Replacement: 14 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 14 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 14 단계, 이미지 3/3
    • Grab the wiring and gently pull it out to disconnect it from the laptop.
    • Don't use excessive force.
    • Remove the keyboard.
  15. HP Pavillion G60-120US LCD Screen Replacement, Display Assembly: 15 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement, Display Assembly: 15 단계, 이미지 2/2
    • Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
    • Avoid using excessive force which may break the cover.
    • Do not completely pull out the cover; there is a wire still attached to the laptop.
  16. HP Pavillion G60-120US LCD Screen Replacement: 16 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 16 단계, 이미지 2/2
    • Using your fingertips, detach the ribbon cable by gently lifting up the black tab located on the bottom end of the cable.
    • Separate the cable and remove the cover.
  17. HP Pavillion G60-120US LCD Screen Replacement: 17 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 17 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 17 단계, 이미지 3/3
    • Remove the mouse and touchpad cable by lifting the black tab and gently pulling the cable out.
  18. HP Pavillion G60-120US LCD Screen Replacement: 18 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 18 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 18 단계, 이미지 3/3
    • Detach the white screen wiring on the bottom left side by gently pulling out.
    • Detach two black screen cables on the middle left side by gently pulling out the cables.
    • Pull out the black cable on the upper right side of the laptop.
    • Use gentle pressure while removing the wires.
  19. HP Pavillion G60-120US LCD Screen Replacement: 19 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 19 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 19 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the four 4.0 mm screws on both hinges of the laptop's screen.
  20. HP Pavillion G60-120US LCD Screen Replacement: 20 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 20 단계, 이미지 2/2
    • Gently lift and detach the display assembly from the laptop’s base.
  21. HP Pavillion G60-120US LCD Screen Replacement, LCD Screen: 21 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement, LCD Screen: 21 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement, LCD Screen: 21 단계, 이미지 3/3
    • Using an opening tool, gently remove the two screw covers from the bottom corners of the screen.
  22. HP Pavillion G60-120US LCD Screen Replacement: 22 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 22 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove two 4.0mm screws from the LCD screen cover.
  23. HP Pavillion G60-120US LCD Screen Replacement: 23 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 23 단계, 이미지 2/2
    • Using an opening tool, gently lift the LCD screen cover and remove the cover.
    • Make sure not to use excessive pressure when detaching and removing the screen cover.
  24. HP Pavillion G60-120US LCD Screen Replacement: 24 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 24 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 24 단계, 이미지 3/3
    • Using your hand, grab the ends of the LCD chip and gently pull it out to detach it from the screen compartment.
    • Be careful not to break the chip when pulling it out.
  25. HP Pavillion G60-120US LCD Screen Replacement: 25 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 25 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 25 단계, 이미지 3/3
    • Disconnect the two screen cables from the LCD chip.
  26. HP Pavillion G60-120US LCD Screen Replacement: 26 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 26 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 26 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the six 4.0mm screws from the LCD screen holder.
    • Remove the two hinges on the bottom edge of the screen.
  27. HP Pavillion G60-120US LCD Screen Replacement: 27 단계, 이미지 1/2 HP Pavillion G60-120US LCD Screen Replacement: 27 단계, 이미지 2/2
    • Lift the screen and screen holder and remove the two cables that are connected to the screen.
    • Lift the plastic tape covering the wiring and gently pull on the wire to detach it.
    • Remove the screen holder and the LCD screen from the screen compartment of the laptop.
  28. HP Pavillion G60-120US LCD Screen Replacement: 28 단계, 이미지 1/3 HP Pavillion G60-120US LCD Screen Replacement: 28 단계, 이미지 2/3 HP Pavillion G60-120US LCD Screen Replacement: 28 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the four 4.0mm screws on each side of the screen holder.
    • Detach and remove the screen holder from the screen.
결론
Won Chan Park
회원 가입일: 09/17/19
670 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 141
