주요 콘텐츠로 건너뛰기
HP Pavillion G7-2235DX Keyboard Replacement
필요한 것
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: 2 단계, 이미지 1/1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: 3 단계, 이미지 1/2 HP Pavillion G7-2235DX Keyboard Replacement: 3 단계, 이미지 2/2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: 4 단계, 이미지 1/1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: 5 단계, 이미지 1/1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: 6 단계, 이미지 1/1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: 7 단계, 이미지 1/2 HP Pavillion G7-2235DX Keyboard Replacement: 7 단계, 이미지 2/2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Bre'Anna Sanders
회원 가입일: 10/11/16
113 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 82
전체 시간: 2,626
