주요 콘텐츠로 건너뛰기
HP Pavillion dm1-3010nr Cooling Fan Replacement
필요한 것
  1. HP Pavillion dm1-3010nr Cooling Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Cooling Fan Replacement: 2 단계, 이미지 1/1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Cooling Fan Replacement, Cooling Fan: 3 단계, 이미지 1/1
    • With the battery removed, the bottom cover can be opened with your hand.
  4. HP Pavillion dm1-3010nr Cooling Fan Replacement: 4 단계, 이미지 1/2 HP Pavillion dm1-3010nr Cooling Fan Replacement: 4 단계, 이미지 2/2
    • Use a screwdriver from your iFixit Toolkit to remove the two 5mm Phillips #0 screws shown in each picture.
    • Use tweezers to carefully remove the fan's power cable from the motherboard. The cable can be seen in the second picture.
  5. HP Pavillion dm1-3010nr Cooling Fan Replacement: 5 단계, 이미지 1/1
    • After removing the screws and unplugging the wire, remove the fan.
결론
Amitpal Gill
회원 가입일: 10/22/18
375 평판
안내서 3개 작성하였습니다
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 회원
UCD-LORE-F18S7G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 579
