주요 콘텐츠로 건너뛰기
HP Pavillion dm1-3010nr Hard Drive Replacement
필요한 것
  1. HP Pavillion dm1-3010nr Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Hard Drive Replacement: 2 단계, 이미지 1/1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • With the battery removed, the back cover can be taken off with your hand.
  4. HP Pavillion dm1-3010nr Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use your Phillips 0 screwdriver to remove the four 2.5mm Phillips screws which hold the hard drive in place. You can see the 4 screws in the picture circled in red.
  5. HP Pavillion dm1-3010nr Hard Drive Replacement: 5 단계, 이미지 1/1
    • To disconnect the hard drive from the motherboard, pull the black tab as seen in the picture.
  6. HP Pavillion dm1-3010nr Hard Drive Replacement: 6 단계, 이미지 1/2 HP Pavillion dm1-3010nr Hard Drive Replacement: 6 단계, 이미지 2/2
    • After removing the enclosure from the device, use your Phillips 0 screwdriver to remove four 3mm Phillips screws. There are two screws on each side of the hard drive enclosure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amitpal Gill
회원 가입일: 10/22/18
375 평판
안내서 3개 작성하였습니다
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 회원
UCD-LORE-F18S7G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Schritt 5 ist leider komplett falsch. Der SATA-Stecker muss von der Festplatte/SSD gezogen werden. Nicht irgendein Kabel vom Motherboard. Den Stecker zieht man einfacher von der HDD/SSD weg, wenn man zuerst Schritt #6 ausführt, dann ist die Metall-Lasche am Kopf des Steckers nicht mehr im Weg.
Peter C. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 21
전체 시간: 1,208
