주요 콘텐츠로 건너뛰기
HP Pavillion dm1-3010nr Keyboard Replacement
필요한 것
  1. HP Pavillion dm1-3010nr Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. HP Pavillion dm1-3010nr Keyboard Replacement: 4 단계, 이미지 2개 중 1개 HP Pavillion dm1-3010nr Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. HP Pavillion dm1-3010nr Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. HP Pavillion dm1-3010nr Keyboard Replacement: 6 단계, 이미지 2개 중 1개 HP Pavillion dm1-3010nr Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
결론
작성자
3다른 기여자 명과 함께
Rosalia Olga Dupont Ayala
회원 가입일: 10/22/18
210 평판
안내서 1개를 작성함
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 회원
UCD-LORE-F18S7G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 16
전체 시간: 769
