소개
You will need to remove many parts of the computer. The key is to be careful when removing some parts of the computer.
필요한 것
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Remove one 5mm Phillips #1 Screw that is securing the optical drive.
With the nylon spudger push the optical drive until you can grab it.
Pull the optical drive all the way out, until removed.
Turn the computer over, and open the computer as far as possible without breaking it.
Release the top of the keyboard by lifting up and gently pull the top up until the whole keyboard is up.
Lift plastic cover to release the ZIF connector that is holding the keyboard in place. Then remove the keyboard.
