주요 콘텐츠로 건너뛰기
HP Pavillion dm4t-2100 Memory Card Replacement
필요한 것
  1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: 1 단계, 이미지 1/2 HP Pavillion dm4t-2100 Memory Card Replacement, Battery: 1 단계, 이미지 2/2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Memory Card Replacement: 2 단계, 이미지 1/3 HP Pavillion dm4t-2100 Memory Card Replacement: 2 단계, 이미지 2/3 HP Pavillion dm4t-2100 Memory Card Replacement: 2 단계, 이미지 3/3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: 3 단계, 이미지 1/2 HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: 3 단계, 이미지 2/2
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  4. HP Pavillion dm4t-2100 Memory Card Replacement: 4 단계, 이미지 1/2 HP Pavillion dm4t-2100 Memory Card Replacement: 4 단계, 이미지 2/2
    • Lift black cover overlaying memory chip.
    • Spread the tabs on each side of the memory slot to release the module.
    • Remove memory by pulling the memory out at an angle, until completely detached.
결론
Brandon Snyder
회원 가입일: 01/06/16
411 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 261
