소개
The purpose of this guide is to teach reader to install a new LCD screen. If the current LCD screen is broken or cracked, this guide will help the reader to replace it with a new one.
필요한 것
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank for this very good job, I own this this camera so it is will be quite easy to fix it following your guide.
