소개
This guide will instruct the user on how to remove and replace the viewfinder mirror and lens on the HP Photosmart 935 Viewfinder Digital Camera. The following instructions can be used as an installation guide for a new viewfinder mirror and lens.
필요한 것
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
Using a Phillips #00 screwdriver, remove the two screws securing the electric strip casing on the back of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
