주요 콘텐츠로 건너뛰기
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 1/2 HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 2/2
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 1/3 HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 2/3 HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 3/3
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 1/3 HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 2/3 HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 3/3
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 1/3 HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 2/3 HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 3/3
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: 5 단계, 이미지 1/2 HP Photosmart C4435 Ink Cartridge Replacement: 5 단계, 이미지 2/2
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: 6 단계, 이미지 1/2 HP Photosmart C4435 Ink Cartridge Replacement: 6 단계, 이미지 2/2
    • Close the ink compartment before using the printer.
결승점
Kalvin Trac
회원 가입일: 09/10/21
133 평판
안내서 1개 작성함
York University, Team 2-11, O'Regan Fall 2021 York University, Team 2-11, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S2G11
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 283
