주요 콘텐츠로 건너뛰기
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 2개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 2개 중 2개
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 3개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 3개 중 2개 HP Photosmart C4435 Ink Cartridge Replacement: 2 단계, 이미지 3개 중 3개
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 3개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 3개 중 2개 HP Photosmart C4435 Ink Cartridge Replacement: 3 단계, 이미지 3개 중 3개
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 3개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 3개 중 2개 HP Photosmart C4435 Ink Cartridge Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: 5 단계, 이미지 2개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement: 5 단계, 이미지 2개 중 2개
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: 6 단계, 이미지 2개 중 1개 HP Photosmart C4435 Ink Cartridge Replacement: 6 단계, 이미지 2개 중 2개
    • Close the ink compartment before using the printer.
결승점
작성자
6다른 기여자 명과 함께
Kalvin Trac
회원 가입일: 09/10/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 459
