주요 콘텐츠로 건너뛰기
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: 1 단계, 이미지 1/1
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: 2 단계, 이미지 1/2 HP Photosmart D110a Ink Cartridge Replacement: 2 단계, 이미지 2/2
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: 3 단계, 이미지 1/1
    • Place the new cartridge into the slot and press firmly until it pops into place.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tim Wise
회원 가입일: 04/01/11
173 평판
안내서 7개 작성하였습니다
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 회원
CPSU-FORTE-S11S10G38
5 회원들
안내서 10개 작성하였습니다
댓글 2개
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - 답글
the HP ink cartridge is 60. Does that make any difference???
April -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 23
전체 시간: 12,219
