주요 콘텐츠로 건너뛰기
HP Photosmart D110a Power Button Replacement
필요한 것
  1. HP Photosmart D110a Power Button Replacement, Power Button: 1 단계, 이미지 1개 중 1개
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: 3 단계, 이미지 3개 중 1개 HP Photosmart D110a Power Button Replacement: 3 단계, 이미지 3개 중 2개 HP Photosmart D110a Power Button Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: 6 단계, 이미지 3개 중 1개 HP Photosmart D110a Power Button Replacement: 6 단계, 이미지 3개 중 2개 HP Photosmart D110a Power Button Replacement: 6 단계, 이미지 3개 중 3개
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: 7 단계, 이미지 3개 중 1개 HP Photosmart D110a Power Button Replacement: 7 단계, 이미지 3개 중 2개 HP Photosmart D110a Power Button Replacement: 7 단계, 이미지 3개 중 3개
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Tim Wise
회원 가입일: 04/01/11
173 평판
안내서 7개를 작성함
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 회원
CPSU-FORTE-S11S10G38
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 3,739
