이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
Locate the three screws on top of the printer.
The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
다른 한 분이 해당 안내서를 완성하였습니다.
